Radiobar 528-37-650
Ok so here is the other side.
I have a 650 chassis with the speaker but the speaker is not a K-17.
I know Lee pulled it out the the 650 tabletop so what is going on?
It is a 10" speaker.
Was mine a replacement?
Pic below.
Radiobar 528-37-650 - by Mike Stover - 03-26-2018, 09:55 AM
RE: Radiobar 528-37-650 - by Radioroslyn - 03-26-2018, 10:44 AM
RE: Radiobar 528-37-650 - by Mike Stover - 03-26-2018, 11:19 AM
RE: Radiobar 528-37-650 - by Radioroslyn - 03-26-2018, 11:56 AM
RE: Radiobar 528-37-650 - by Mike Stover - 03-26-2018, 12:48 PM
RE: Radiobar 528-37-650 - by Ron Ramirez - 03-26-2018, 12:52 PM
RE: Radiobar 528-37-650 - by Mike Stover - 03-26-2018, 03:35 PM
RE: Radiobar 528-37-650 - by Mike Stover - 03-26-2018, 04:01 PM
RE: Radiobar 528-37-650 - by Ron Ramirez - 03-26-2018, 04:27 PM
RE: Radiobar 528-37-650 - by OldRestorer - 03-26-2018, 07:09 PM
RE: Radiobar 528-37-650 - by Ron Ramirez - 03-26-2018, 09:34 PM
RE: Radiobar 528-37-650 - by OldRestorer - 03-27-2018, 12:57 PM
RE: Radiobar 528-37-650 - by Ron Ramirez - 03-27-2018, 05:33 PM
RE: Radiobar 528-37-650 - by OldRestorer - 03-27-2018, 05:57 PM
RE: Radiobar 528-37-650 - by Ron Ramirez - 03-27-2018, 07:02 PM
