Model 90 Cathedral advice
Good Morning all -
I recently picked up a model 90 cathedral.  Original finish and clean except for bypassed electrolytics and 3 older caps on Bakelite blocks.  It needed new tuning capacitor bushings which I replaced this past weekend.
Is there a risk of playing it too much without a full re-cap?  I've read a number of differing opinions from, play it till something goes wrong and then fix the issue, to recap the entire set from the beginning.   I'm planning to re-stuff the original cans along with the Bakelite blocks this summer.  It plays well now but I haven't played it much.
Model 90 Cathedral advice - by WyTex - 03-27-2018, 10:47 AM
RE: Model 90 Cathedral advice - by morzh - 03-27-2018, 12:15 PM
RE: Model 90 Cathedral advice - by Radioroslyn - 03-27-2018, 12:21 PM
RE: Model 90 Cathedral advice - by Ron Ramirez - 03-27-2018, 05:36 PM
RE: Model 90 Cathedral advice - by WyTex - 03-28-2018, 04:49 AM
RE: Model 90 Cathedral advice - by morzh - 03-28-2018, 08:12 AM
RE: Model 90 Cathedral advice - by Paul Philco322 - 03-28-2018, 09:29 PM
RE: Model 90 Cathedral advice - by Arran - 03-29-2018, 12:23 AM
RE: Model 90 Cathedral advice - by WyTex - 03-29-2018, 12:58 PM
RE: Model 90 Cathedral advice - by morzh - 03-29-2018, 01:30 PM
RE: Model 90 Cathedral advice - by Arran - 03-30-2018, 05:03 AM
RE: Model 90 Cathedral advice - by morzh - 03-30-2018, 08:56 AM
RE: Model 90 Cathedral advice - by Tim Tress - 04-07-2018, 09:03 AM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 6999 online users. [Complete List]
» 1 Member(s) | 6998 Guest(s)
