model 84b
As another data point I can add that I changed to the 2 meg resistor on two model 84's I've worked on over the last year.  Made quite a noticeable difference for mine too.
model 84b - by falcon123 - 03-28-2018, 02:32 AM
RE: model 84b - by Radioroslyn - 03-28-2018, 04:49 AM
RE: model 84b - by falcon123 - 03-28-2018, 06:05 AM
RE: model 84b - by morzh - 03-28-2018, 08:08 AM
RE: model 84b - by falcon123 - 03-28-2018, 08:46 AM
RE: model 84b - by OldRestorer - 03-28-2018, 09:52 AM
RE: model 84b - by Radioroslyn - 03-28-2018, 10:55 AM
RE: model 84b - by Ron Ramirez - 03-28-2018, 11:56 AM
RE: model 84b - by dacsman - 03-28-2018, 01:47 PM
RE: model 84b - by falcon123 - 03-29-2018, 12:58 AM
RE: model 84b - by Radioroslyn - 03-29-2018, 08:27 AM
RE: model 84b - by falcon123 - 03-30-2018, 01:37 AM
RE: model 84b - by Radioroslyn - 03-30-2018, 10:14 AM
RE: model 84b - by falcon123 - 04-01-2018, 04:53 AM
RE: model 84b - by falcon123 - 04-02-2018, 04:29 AM
RE: model 84b - by Radioroslyn - 04-02-2018, 10:15 AM
RE: model 84b - by falcon123 - 04-03-2018, 12:07 AM
RE: model 84b - by Radioroslyn - 04-03-2018, 11:19 AM
91H Code 126 Restore
