model 84b
well after a morning cleaning the chassiss and deoxiting the aircap and the volume control, sorting through two disconnected wires i discovered that volume control 33-5055 is supposed to be 20k it is actually 46k and after a fader lube service is linear. i tried to look it up in the 1936 parts catalog but it isnt listed. is the drawing wrong? the control itself is clearly labeled philco335055. the missing power supply combo ecap was replaced by two ancient illinoiis cardboard case caps crudely stuffed in the chassis
model 84b - by falcon123 - 03-28-2018, 02:32 AM
RE: model 84b - by Radioroslyn - 03-28-2018, 04:49 AM
RE: model 84b - by falcon123 - 03-28-2018, 06:05 AM
RE: model 84b - by morzh - 03-28-2018, 08:08 AM
RE: model 84b - by falcon123 - 03-28-2018, 08:46 AM
RE: model 84b - by OldRestorer - 03-28-2018, 09:52 AM
RE: model 84b - by Radioroslyn - 03-28-2018, 10:55 AM
RE: model 84b - by Ron Ramirez - 03-28-2018, 11:56 AM
RE: model 84b - by dacsman - 03-28-2018, 01:47 PM
RE: model 84b - by falcon123 - 03-29-2018, 12:58 AM
RE: model 84b - by Radioroslyn - 03-29-2018, 08:27 AM
RE: model 84b - by falcon123 - 03-30-2018, 01:37 AM
RE: model 84b - by Radioroslyn - 03-30-2018, 10:14 AM
RE: model 84b - by falcon123 - 04-01-2018, 04:53 AM
RE: model 84b - by falcon123 - 04-02-2018, 04:29 AM
RE: model 84b - by Radioroslyn - 04-02-2018, 10:15 AM
RE: model 84b - by falcon123 - 04-03-2018, 12:07 AM
RE: model 84b - by Radioroslyn - 04-03-2018, 11:19 AM
91H Code 126 Restore
