37-116 (122) - Audio Interstage Transformer - Modification
It good to see you made the trip over here from ARF. In addition, I'm glad you were able to find a good transformer at Play things of the Past. After reading your post talking about plan A, on ARF, I am wondering if I too should protect the transformer on my 38-116. Hopefully some one will answer you soon.
Rod
Re: 37-116 (122) - Audio Interstage Transformer - Modificati - by hotrod - 05-27-2010, 12:07 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6129 online users. [Complete List]
» 1 Member(s) | 6128 Guest(s)
