37-116 (122) - Audio Interstage Transformer - Modification
Thanks for the advice to come here.
Yes, I could not believe he had one. I looked on several pages, inquired as advised, but nothing came up. As it turns out, he (Gary) had one on the "Driver" page. I about fell over trying to get my wallet out! I asked him to check the DC resistance on all sides... he said it is within spec of the schematic values I gave him.
ARF people have countless times come between me and disaster. Its going to take me a long time to get the skills & knowledge you and others have. I can replace or replicate a radio... anybody can do that... but I can't modify a circuit. That's where these forums come in.
I'll be back.
John
Re: 37-116 (122) - Audio Interstage Transformer - Modificati - by spfradios2 - 05-27-2010, 01:10 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
