41-608 Transformer
> Are the transformers the same for Chassis 121 and Chassis 122?
Yes - original part # is 32-8132.
Primary - 115-120 V
HV - 525 VCT @ 65 mA
Fil. #1 - 6.4V @ 3A
Fil. #2 - 6.4V @ 2A
Information from the 1941 Philco Parts Catalog
41-608 Transformer - by cougar01 - 03-26-2018, 08:34 PM
RE: 41-608 Transformer - by klondike98 - 03-26-2018, 09:29 PM
RE: 41-608 Transformer - by Radioroslyn - 03-26-2018, 11:05 PM
RE: 41-608 Transformer - by sam - 03-27-2018, 11:25 AM
RE: 41-608 Transformer - by cougar01 - 03-27-2018, 12:02 PM
RE: 41-608 Transformer - by cougar01 - 03-29-2018, 09:03 PM
RE: 41-608 Transformer - by Ron Ramirez - 03-29-2018, 09:39 PM
RE: 41-608 Transformer - by cougar01 - 03-29-2018, 10:36 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 5001 online users. [Complete List]
» 3 Member(s) | 4998 Guest(s)
