Pilot lamp for Philco 42-323 code 122
I am restoring this radio and the pilot lamp is missing. The schematic indicates it is Philco part # 34-2477 and from its connections in the circuit, it appears to be a 110 volt bulb. It has a screw base which is about 3/8 inches in diameter.
Can anyone suggest a suitable replacement and where can I buy it?
Barry
Pilot lamp for Philco 42-323 code 122 - by Guest - 05-27-2010, 05:28 PM
Re: Pilot lamp for Philco 42-323 code 122 - by Guest - 05-27-2010, 09:43 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
