Philco Square Tube Shield Restoration
Thank you,
Replating looks to be the way to go. I'll see what the costs look like and let you know. I might see if nickel plating would work better, it should last longer and provide a similar look.
RE: Philco Square Tube Shield Restoration - by wardmc1 - 03-30-2018, 08:27 PM
The speaker table error?
Philco 70 antenna lead
