Philco 37-116
Hi Russ, It does look like the veneer is going to be difficult to fix. There is a woodworking place that is near me that I may check out to see if they can fix the veneer damage and what the cost would be otherwise I'll try to fix it the best I can till I can get a replacement cabinet. I do like your website.  Ken
Philco 37-116 - by Kenradio - 03-30-2018, 04:52 PM
RE: Philco 37-116 - by PhilcoJohn - 03-30-2018, 07:30 PM
RE: Philco 37-116 - by PhilcoJohn - 03-30-2018, 07:31 PM
RE: Philco 37-116 - by Phlogiston - 03-30-2018, 10:02 PM
RE: Philco 37-116 - by Kenradio - 03-31-2018, 02:03 AM
RE: Philco 37-116 - by Kenradio - 03-31-2018, 02:17 AM
RE: Philco 37-116 - by Phlogiston - 03-31-2018, 10:33 AM
There are currently 7713 online users. [Complete List]
» 3 Member(s) | 7710 Guest(s)
