Philco 604 Bias Cell
Hi, Arran:
Thanks for taking the time to think about my problem.  Someone here did send me a schematic for a Philco 38-14, where they threw in a couple of resistors in the "power supply" kind of sort of in parallel with the ballast resistor, to bias the cathode.  I considered it, but the way it was done looks like a major rewiring job.  I fooled with this for 3 hours last night and decided I will just modify it for an LR44 cell and move on.
I read the part about replacing the ballast resistor with diodes or capacitors.  Did I read that correctly?  I've never heard of that.  Can you elaborate a little more on that?  Maybe post a sketch?
I'm having trouble with my audio in this set as well, which was one of the reasons I have been trying so hard to get this bias thing right.  My audio is not clean.  It is a little garbled, sounding like there is 60 cycle hum mixed in with it.  I replaced all the caps and any resistor outside 10%.   I've swapped out all the tubes.  There is about 2v of ripple on the B- relative to chassis, and I see it on the 75 tube grid and plate.  Not so much on the 43 plate.  I don't know if this ever happens to you, but I have become so frustrated with this set that I am going to set it aside and cool off for a while.  I've got a model 20 to start on, but first I need to repair the transmission in my brother's tractor/backhoe, which should keep my mind off of this for a couple of weeks.  If I don't get inspired beforehand, I will try to post more details about the audio problem in a separate thread.  I am beginning to suspect a problem with my bench setup, as I have had this problem on 2 other sets and never could get it satisfactorily resolved.
Again, Thanks!
Mike
Philco 604 Bias Cell - by mboessen - 03-28-2018, 03:37 PM
RE: Philco 604 Bias Cell - by morzh - 03-28-2018, 05:02 PM
RE: Philco 604 Bias Cell - by mboessen - 03-28-2018, 08:28 PM
RE: Philco 604 Bias Cell - by PhilcoPhan1936 - 03-29-2018, 04:16 AM
RE: Philco 604 Bias Cell - by Arran - 03-29-2018, 05:12 AM
RE: Philco 604 Bias Cell - by David - 03-29-2018, 08:24 AM
RE: Philco 604 Bias Cell - by Radioroslyn - 03-29-2018, 08:44 AM
RE: Philco 604 Bias Cell - by mboessen - 03-29-2018, 09:24 AM
RE: Philco 604 Bias Cell - by 462ron - 03-29-2018, 10:12 AM
RE: Philco 604 Bias Cell - by morzh - 03-29-2018, 10:47 AM
RE: Philco 604 Bias Cell - by mboessen - 03-29-2018, 10:57 AM
RE: Philco 604 Bias Cell - by mboessen - 03-29-2018, 11:00 AM
RE: Philco 604 Bias Cell - by 462ron - 03-29-2018, 01:34 PM
RE: Philco 604 Bias Cell - by mboessen - 03-29-2018, 03:06 PM
RE: Philco 604 Bias Cell - by mboessen - 03-29-2018, 09:31 PM
RE: Philco 604 Bias Cell - by mboessen - 03-29-2018, 09:39 PM
RE: Philco 604 Bias Cell - by Radioroslyn - 03-29-2018, 10:14 PM
RE: Philco 604 Bias Cell - by 462ron - 03-29-2018, 10:30 PM
RE: Philco 604 Bias Cell - by Radioroslyn - 03-29-2018, 11:04 PM
RE: Philco 604 Bias Cell - by mboessen - 03-30-2018, 08:49 AM
RE: Philco 604 Bias Cell - by 462ron - 03-30-2018, 10:07 AM
RE: Philco 604 Bias Cell - by Radioroslyn - 03-30-2018, 12:22 PM
RE: Philco 604 Bias Cell - by mboessen - 03-30-2018, 07:41 PM
RE: Philco 604 Bias Cell - by Arran - 03-31-2018, 02:20 AM
RE: Philco 604 Bias Cell - by mboessen - 03-31-2018, 10:32 AM
The speaker table error?
Philco 70 antenna lead
There are currently 6657 online users. [Complete List]
» 2 Member(s) | 6655 Guest(s)
