47 1230 no fm
Ok If you have 6 ohms then you should have hv on pin 6.
Would check the contacts on the bandswitch (FS 2) . Hv comes in from R300 and goes to the switch contacts. In fm the switch shorts the primary of the AM if coil (lower left coil in Z300 leaving the hv to pass thru the primary of the fm if coil (top left coil in Z300). Follow the hv from R300 up thru the switch and Z300 where it stops is your faulty part.
47 1230 no fm - by willydcamaro - 01-31-2018, 05:35 PM
RE: 47 1230 no fm - by klondike98 - 01-31-2018, 07:32 PM
RE: 47 1230 no fm - by Warren - 02-01-2018, 07:21 PM
RE: 47 1230 no fm - by willydcamaro - 02-03-2018, 10:02 AM
RE: 47 1230 no fm - by willydcamaro - 02-07-2018, 07:10 PM
RE: 47 1230 no fm - by klondike98 - 02-07-2018, 07:34 PM
RE: 47 1230 no fm - by willydcamaro - 02-07-2018, 07:50 PM
RE: 47 1230 no fm - by klondike98 - 02-07-2018, 08:01 PM
RE: 47 1230 no fm - by Ron Ramirez - 02-07-2018, 08:14 PM
RE: 47 1230 no fm - by willydcamaro - 02-07-2018, 08:31 PM
RE: 47 1230 no fm - by willydcamaro - 02-08-2018, 06:10 AM
RE: 47 1230 no fm - by willydcamaro - 02-09-2018, 05:43 PM
RE: 47 1230 no fm - by Ron Ramirez - 02-09-2018, 06:44 PM
RE: 47 1230 no fm - by willydcamaro - 02-11-2018, 02:53 PM
RE: 47 1230 no fm - by Radioroslyn - 02-11-2018, 04:10 PM
RE: 47 1230 no fm - by willydcamaro - 02-11-2018, 05:47 PM
RE: 47 1230 no fm - by willydcamaro - 03-31-2018, 08:32 AM
RE: 47 1230 no fm - by Radioroslyn - 03-31-2018, 11:04 AM
RE: 47 1230 no fm - by willydcamaro - 03-31-2018, 11:16 AM
RE: 47 1230 no fm - by willydcamaro - 03-31-2018, 05:17 PM
RE: 47 1230 no fm - by Radioroslyn - 03-31-2018, 06:00 PM
RE: 47 1230 no fm - by willydcamaro - 03-31-2018, 07:37 PM
RE: 47 1230 no fm - by willydcamaro - 03-31-2018, 08:39 PM
RE: 47 1230 no fm - by Radioroslyn - 03-31-2018, 08:55 PM
RE: 47 1230 no fm - by willydcamaro - 03-31-2018, 09:03 PM
RE: 47 1230 no fm - by Radioroslyn - 03-31-2018, 09:13 PM
RE: 47 1230 no fm - by willydcamaro - 03-31-2018, 09:31 PM
RE: 47 1230 no fm - by Radioroslyn - 03-31-2018, 09:55 PM
RE: 47 1230 no fm - by willydcamaro - 04-05-2018, 11:41 PM
RE: 47 1230 no fm - by willydcamaro - 04-06-2018, 05:08 AM
RE: 47 1230 no fm - by willydcamaro - 04-07-2018, 07:13 PM
RE: 47 1230 no fm - by willydcamaro - 04-09-2018, 07:52 PM
RE: 47 1230 no fm - by willydcamaro - 04-30-2018, 07:44 PM
RE: 47 1230 no fm - by Marsupial - 08-01-2018, 07:17 AM
91H Code 126 Restore
