speaker question.
Nope, the 71B used a K-7 speaker which has an 1125 ohm field coil. 20, 70 and 90 cathedral speakers all have 3100 ohm field coils.
more info here:
http://www.philcoradio.com/phorum/showth...hp?tid=215
Scroll down to, and download speakers.zip which was made in and intended for Microsoft Excel but also works in LibreOffice Calc and OpenOffice Calc.
speaker question. - by sumnerplace - 03-31-2018, 05:57 PM
RE: speaker question. - by Radioroslyn - 03-31-2018, 06:17 PM
RE: speaker question. - by Ron Ramirez - 03-31-2018, 06:46 PM
RE: speaker question. - by sumnerplace - 03-31-2018, 06:48 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3938 online users. [Complete List]
» 1 Member(s) | 3937 Guest(s)
