42-1008P 10 inch Record Start Adjustment
Ok so here is a video. Everything is still working fine it was just the cable on that 10 inch flapper that came off the pulley. Messing with it in the position I started it out with in the video causes slack and then it came off.
Also just FYI both of those records are crap and so is my needle. This is all about functionality at this point. I was not worried about harming either record or needle.
linky
RE: 42-1008P 10 inch Record Start Adjustment - by Edisla - 04-01-2018, 09:21 PM
91H Code 126 Restore
There are currently 2895 online users. [Complete List]
» 2 Member(s) | 2893 Guest(s)
