Philco 90 tone control
Hi everyone,
Does anyone know what value caps I need to replace the 3 inside the tone control metal box? Trying to get this re-cap complete and I haven't a clue! Icon_sad
I've done most of the other re-capping....was motorboating badly, then noticed the tone control looking pretty bad....hanging right off the output (47) tube plate.
Thanks in advance,
Joe
Philco 90 tone control - by joeinri - 05-29-2010, 03:26 PM
Re: Philco 90 tone control - by Ron Ramirez - 05-29-2010, 05:41 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
