42-1008P 10 inch Record Start Adjustment
Feel like I'm talking to myself but I do have a question.
In manual mode when the record is done the needle stays down and just spins on the record right?
When in automatic mode it will continue to replay a record?
This is all the correct behavior?
RE: 42-1008P 10 inch Record Start Adjustment - by Edisla - 04-01-2018, 11:05 PM
91H Code 126 Restore
