model 84b
>are you running a polarized plug ensuring the hot is switched?
No, You can if you like not a big deal. I don't particularity like them as they don't fit into some receptacles.
> but it seems that 10mfd  50vcap from the ct to ground (28) wouldn't be too happy if you didn't,especially as the chassis must be grounded.
Well the 10 mfd doesn't care at all about the mains polarization as it is isolated thru the power transformer. It's strictly there to filter the negative dc voltage. The other part of 28 (.015) on the primary of the transformer gives the chassis a rf ground thru the neutral side of the mains. It's better to connect an earth ground (one not related to the mains ground or neutral) as the mains can carry a lot of noise.
model 84b - by falcon123 - 03-28-2018, 02:32 AM
RE: model 84b - by Radioroslyn - 03-28-2018, 04:49 AM
RE: model 84b - by falcon123 - 03-28-2018, 06:05 AM
RE: model 84b - by morzh - 03-28-2018, 08:08 AM
RE: model 84b - by falcon123 - 03-28-2018, 08:46 AM
RE: model 84b - by OldRestorer - 03-28-2018, 09:52 AM
RE: model 84b - by Radioroslyn - 03-28-2018, 10:55 AM
RE: model 84b - by Ron Ramirez - 03-28-2018, 11:56 AM
RE: model 84b - by dacsman - 03-28-2018, 01:47 PM
RE: model 84b - by falcon123 - 03-29-2018, 12:58 AM
RE: model 84b - by Radioroslyn - 03-29-2018, 08:27 AM
RE: model 84b - by falcon123 - 03-30-2018, 01:37 AM
RE: model 84b - by Radioroslyn - 03-30-2018, 10:14 AM
RE: model 84b - by falcon123 - 04-01-2018, 04:53 AM
RE: model 84b - by falcon123 - 04-02-2018, 04:29 AM
RE: model 84b - by Radioroslyn - 04-02-2018, 10:15 AM
RE: model 84b - by falcon123 - 04-03-2018, 12:07 AM
RE: model 84b - by Radioroslyn - 04-03-2018, 11:19 AM
The speaker table error?
Philco 70 antenna lead
There are currently 5852 online users. [Complete List]
» 1 Member(s) | 5851 Guest(s)
