Philco Model 37-61 Owners Manual
Here is the owners manual that came with my Philco Model 37-61 F Console Radio. I thought others might want a copy of this manual.
[Image: http://i131.photobucket.com/albums/p294/...Page01.jpg]
[Image: http://i131.photobucket.com/albums/p294/...Page02.jpg]
[Image: http://i131.photobucket.com/albums/p294/...Page03.jpg]
[Image: http://i131.photobucket.com/albums/p294/...Page04.jpg]
[Image: http://i131.photobucket.com/albums/p294/...Page05.jpg]
[Image: http://i131.photobucket.com/albums/p294/...Page06.jpg]
Philco Model 37-61 Owners Manual - by Guest - 05-29-2010, 06:41 PM
Re: Philco Model 37-61 Owners Manual - by Guest - 05-30-2010, 12:50 PM
Re: Philco Model 37-61 Owners Manual - by Rguess - 11-21-2010, 11:37 PM
Philco 91 Tuning Condenser
There are currently 9297 online users. [Complete List]
» 1 Member(s) | 9296 Guest(s)
