Hickok 600A tube tester
Ok Opened up the tester..
[Image: https://farm1.staticflickr.com/897/41214...9feb_b.jpg]
Does anyone have a layout of the bottom on what is what? Resistors Caps Pots ETC..
Here is a resistor board?? What are the values supposed to be and what parts are they??
[Image: https://farm1.staticflickr.com/806/41214...172b_b.jpg]
Skip...
Hickok 600A tube tester - by vecher - 03-03-2018, 09:20 PM
RE: Hickok 600A tube tester - by vecher - 03-03-2018, 10:09 PM
RE: Hickok 600A tube tester - by gregb - 03-04-2018, 12:02 AM
RE: Hickok 600A tube tester - by morzh - 03-04-2018, 12:33 AM
RE: Hickok 600A tube tester - by vecher - 03-04-2018, 12:45 AM
RE: Hickok 600A tube tester - by gregb - 03-04-2018, 08:28 AM
RE: Hickok 600A tube tester - by morzh - 03-04-2018, 11:20 AM
RE: Hickok 600A tube tester - by vecher - 03-04-2018, 03:00 PM
RE: Hickok 600A tube tester - by morzh - 03-04-2018, 03:20 PM
RE: Hickok 600A tube tester - by vecher - 04-03-2018, 02:15 PM
RE: Hickok 600A tube tester - by morzh - 04-03-2018, 03:14 PM
RE: Hickok 600A tube tester - by vecher - 04-03-2018, 03:32 PM
RE: Hickok 600A tube tester - by vecher - 05-17-2018, 09:11 PM
RE: Hickok 600A tube tester - by morzh - 05-17-2018, 09:21 PM
RE: Hickok 600A tube tester - by vecher - 05-17-2018, 09:30 PM
RE: Hickok 600A tube tester - by vecher - 07-01-2018, 08:29 PM
RE: Hickok 600A tube tester - by Phlogiston - 07-01-2018, 11:44 PM
RE: Hickok 600A tube tester - by morzh - 07-02-2018, 08:49 AM
RE: Hickok 600A tube tester - by vecher - 07-02-2018, 01:44 PM
RE: Hickok 600A tube tester - by John R - 07-02-2018, 06:21 PM
RE: Hickok 600A tube tester - by vecher - 07-02-2018, 08:34 PM
RE: Hickok 600A tube tester - by vecher - 07-03-2018, 08:22 PM
