Silvertone 4586 Console
I would ohm out the windings on the If transformers, see if one side is open on either of them, you don't need a signal generator for that. One thing to watch for are flaky leads on the grid caps, that can cause problems.
Silvertone 4586 Console - by murf - 02-19-2018, 11:05 PM
RE: Silvertone 4586 Console - by Paul Philco322 - 02-25-2018, 09:41 PM
RE: Silvertone 4586 Console - by Arran - 02-25-2018, 10:09 PM
RE: Silvertone 4586 Console - by murf - 02-25-2018, 11:59 PM
RE: Silvertone 4586 Console - by Radioroslyn - 02-26-2018, 12:30 AM
RE: Silvertone 4586 Console - by murf - 02-26-2018, 06:40 PM
RE: Silvertone 4586 Console - by tbone - 02-26-2018, 08:15 PM
RE: Silvertone 4586 Console - by murf - 02-26-2018, 08:41 PM
RE: Silvertone 4586 Console - by Arran - 03-09-2018, 04:29 AM
RE: Silvertone 4586 Console - by murf - 03-09-2018, 01:35 PM
RE: Silvertone 4586 Console - by murf - 03-14-2018, 06:22 PM
RE: Silvertone 4586 Console - by Arran - 03-15-2018, 04:45 AM
RE: Silvertone 4586 Console - by Arran - 03-17-2018, 08:41 PM
RE: Silvertone 4586 Console - by murf - 03-18-2018, 11:26 AM
RE: Silvertone 4586 Console - by Arran - 03-26-2018, 01:51 AM
RE: Silvertone 4586 Console - by murf - 03-26-2018, 04:11 PM
RE: Silvertone 4586 Console - by murf - 03-26-2018, 10:32 PM
RE: Silvertone 4586 Console - by murf - 03-27-2018, 09:58 PM
RE: Silvertone 4586 Console - by murf - 04-03-2018, 03:31 PM
RE: Silvertone 4586 Console - by Radioroslyn - 04-03-2018, 04:30 PM
RE: Silvertone 4586 Console - by murf - 04-03-2018, 05:58 PM
RE: Silvertone 4586 Console - by morzh - 04-03-2018, 08:28 PM
RE: Silvertone 4586 Console - by murf - 04-03-2018, 09:44 PM
RE: Silvertone 4586 Console - by Arran - 04-05-2018, 04:46 AM
RE: Silvertone 4586 Console - by murf - 04-05-2018, 03:37 PM
RE: Silvertone 4586 Console - by Phlogiston - 04-05-2018, 04:11 PM
RE: Silvertone 4586 Console - by Arran - 04-06-2018, 12:02 AM
RE: Silvertone 4586 Console - by murf - 04-08-2018, 01:25 PM
RE: Silvertone 4586 Console - by murf - 04-17-2018, 08:17 PM
RE: Silvertone 4586 Console - by Radioroslyn - 04-17-2018, 09:43 PM
RE: Silvertone 4586 Console - by murf - 04-24-2018, 06:40 PM
RE: Silvertone 4586 Console - by Radioroslyn - 04-24-2018, 08:52 PM
RE: Silvertone 4586 Console - by murf - 04-25-2018, 08:04 PM
RE: Silvertone 4586 Console - by Radioroslyn - 04-25-2018, 09:02 PM
RE: Silvertone 4586 Console - by murf - 05-01-2018, 06:04 PM
