Three GE Transistor Radios
Meet "Pickle", olive green P-809C posing with freshly Sharpie'd P-807J..
I'm yet to see service literature for a C model, it's PCB is somewhat different than the B & E that are lumped together(at least in Sams)...
Can spot the later models by lack of CD symbols & reversed dial scale numbering...
Three GE Transistor Radios - by Jayce - 03-12-2018, 04:46 PM
RE: Three GE Transistor Radios - by David - 03-12-2018, 07:32 PM
RE: Three GE Transistor Radios - by Jayce - 03-12-2018, 09:47 PM
RE: Three GE Transistor Radios - by David - 03-13-2018, 07:47 AM
RE: Three GE Transistor Radios - by 35Z5 - 03-13-2018, 09:51 AM
RE: Three GE Transistor Radios - by Jayce - 03-13-2018, 05:10 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-13-2018, 08:55 PM
RE: Three GE Transistor Radios - by Jayce - 03-13-2018, 09:15 PM
RE: Three GE Transistor Radios - by David - 03-13-2018, 09:19 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-13-2018, 09:51 PM
RE: Three GE Transistor Radios - by Arran - 03-14-2018, 12:07 AM
RE: Three GE Transistor Radios - by 35Z5 - 03-14-2018, 11:28 AM
RE: Three GE Transistor Radios - by Jayce - 03-14-2018, 12:12 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-14-2018, 05:11 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-19-2018, 05:02 PM
RE: Three GE Transistor Radios - by Jayce - 03-19-2018, 10:11 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-19-2018, 11:42 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-30-2018, 05:49 PM
RE: Three GE Transistor Radios - by Jayce - 03-30-2018, 11:51 PM
RE: Three GE Transistor Radios - by 35Z5 - 03-31-2018, 08:39 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-02-2018, 08:03 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-05-2018, 09:48 AM
RE: Three GE Transistor Radios - by Jayce - 04-06-2018, 10:06 PM
RE: Three GE Transistor Radios - by 35Z5 - 04-07-2018, 12:02 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-08-2018, 10:46 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-12-2018, 08:46 PM
RE: Three GE Transistor Radios - by Jayce - 04-12-2018, 10:13 PM
RE: Three GE Transistor Radios - by 35Z5 - 04-18-2018, 11:51 AM
RE: Three GE Transistor Radios - by 35Z5 - 04-25-2018, 06:34 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-05-2018, 03:40 PM
RE: Three GE Transistor Radios - by Jayce - 05-05-2018, 04:45 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-05-2018, 11:25 PM
RE: Three GE Transistor Radios - by jcassity - 05-12-2018, 08:20 AM
RE: Three GE Transistor Radios - by 35Z5 - 05-27-2018, 06:18 PM
RE: Three GE Transistor Radios - by sam - 05-27-2018, 06:45 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-30-2018, 06:02 PM
RE: Three GE Transistor Radios - by Jayce - 05-31-2018, 12:18 AM
RE: Three GE Transistor Radios - by 35Z5 - 05-31-2018, 10:23 AM
RE: Three GE Transistor Radios - by Jayce - 05-31-2018, 02:54 PM
RE: Three GE Transistor Radios - by 35Z5 - 05-31-2018, 09:26 PM
RE: Three GE Transistor Radios - by 35Z5 - 06-05-2018, 04:40 PM
There are currently 8617 online users. [Complete List]
» 1 Member(s) | 8616 Guest(s)
