Local/Distant switch
Hi,
Over the years there were many versions of a switch for that function. Some had a phenolic wafer, other used a toggle switch on an offset arm.
Can you post a couple of clear, well lit images of the broken switch? Also an image of where it is supposed to fit so one could judge if a substitute would fit... The diameter of the mounting hole?
Regards,
Chas
Pliny the younger
Local/Distant switch - by lasurveyor - 04-05-2018, 05:41 PM
RE: Local/Distant switch - by Chas - 04-05-2018, 11:36 PM
RE: Local/Distant switch - by Phlogiston - 04-06-2018, 12:03 PM
RE: Local/Distant switch - by lasurveyor - 04-06-2018, 12:36 PM
RE: Local/Distant switch - by lasurveyor - 04-06-2018, 12:39 PM
RE: Local/Distant switch - by lasurveyor - 04-06-2018, 04:33 PM
RE: Local/Distant switch - by Chas - 04-06-2018, 09:12 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4357 online users. [Complete List]
» 1 Member(s) | 4356 Guest(s)
