Restoring a Predicta Tandem
#41
I would not bother with the wire wrapping tool, unless it's cheap and you just want something to try. I suspect that the ends may break off the ends before you get them wrapped around again, soldering them onto the posts is probably easier both to put them on and remove again should you need to, just make sure you sand them a bit first to get the oxidation off, 320 grit paper will do.
Restoring a Predicta Tandem - by apERNA1985 - 02-27-2018, 02:39 PM
RE: Restoring a Predicta Tandem - by Radioroslyn - 02-27-2018, 05:01 PM
RE: Restoring a Predicta Tandem - by Radioroslyn - 02-27-2018, 06:40 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 02-27-2018, 11:08 PM
RE: Restoring a Predicta Tandem - by Radioroslyn - 02-28-2018, 03:46 PM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-01-2018, 12:27 PM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-01-2018, 01:03 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-01-2018, 01:13 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-01-2018, 01:18 PM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-01-2018, 02:55 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-06-2018, 11:56 AM
RE: Restoring a Predicta Tandem - by Radioroslyn - 03-06-2018, 06:07 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-06-2018, 08:01 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-07-2018, 08:54 AM
RE: Restoring a Predicta Tandem - by gregb - 03-07-2018, 10:06 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-07-2018, 11:39 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-07-2018, 12:24 PM
RE: Restoring a Predicta Tandem - by Radioroslyn - 03-07-2018, 01:06 PM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-07-2018, 01:29 PM
RE: Restoring a Predicta Tandem - by TV MAN - 03-11-2018, 06:39 PM
RE: Restoring a Predicta Tandem - by Arran - 03-13-2018, 04:00 AM
RE: Restoring a Predicta Tandem - by TV MAN - 03-13-2018, 09:03 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-17-2018, 09:19 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-19-2018, 11:47 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-19-2018, 12:03 PM
RE: Restoring a Predicta Tandem - by Radioroslyn - 03-19-2018, 12:57 PM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-19-2018, 03:25 PM
RE: Restoring a Predicta Tandem - by Arran - 03-22-2018, 04:55 AM
RE: Restoring a Predicta Tandem - by Bob Andersen - 03-22-2018, 08:31 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-23-2018, 08:17 AM
RE: Restoring a Predicta Tandem - by Arran - 03-24-2018, 01:27 AM
RE: Restoring a Predicta Tandem - by TV MAN - 03-29-2018, 11:12 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 03-29-2018, 12:19 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 04-06-2018, 10:57 AM
RE: Restoring a Predicta Tandem - by gregb - 04-06-2018, 12:13 PM
RE: Restoring a Predicta Tandem - by apERNA1985 - 04-06-2018, 03:52 PM
RE: Restoring a Predicta Tandem - by gregb - 04-06-2018, 04:06 PM
RE: Restoring a Predicta Tandem - by gregb - 04-06-2018, 06:36 PM
RE: Restoring a Predicta Tandem - by Arran - 04-07-2018, 04:26 AM
RE: Restoring a Predicta Tandem - by apERNA1985 - 04-26-2018, 05:40 AM
RE: Restoring a Predicta Tandem - by gregb - 04-26-2018, 09:01 AM
