#54
Ok, checked as you said radioslyn, hope pin one is the same that are you talking about...from pin 1 to chassis I have only 258ohm and pin 4 460ohm... Any hint for a trouble?
Thanks
Philco 37-610 tombstone restoration - by Jeepeto - 02-09-2018, 08:58 AM
RE: Philco 37-610 tombstone restoration - by Jeepeto - 04-07-2018, 11:38 AM
Users browsing this thread: 22 Guest(s)
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4960 online users. [Complete List]
» 2 Member(s) | 4958 Guest(s)
