Chassis Restoration
It occurred to me last night that this should be added for newbies:
SOME CHASSIS AND PARTS ARE PLATED WITH CADMIUM. CADMIUM IS VERY POISIONOUS. FRIABLE  (DUST) MATERIAL CAN BE INHALED. THIS MUST BE AVOIDED. SANDING A CADIMIUM PLATED CHASSIS IS UNSAFE AND MUST BE AVOIDED.
Chassis Restoration - by wardmc1 - 04-06-2018, 01:12 PM
RE: Chassis Restoration - by Phlogiston - 04-06-2018, 05:20 PM
RE: Chassis Restoration - by wardmc1 - 04-06-2018, 08:06 PM
RE: Chassis Restoration - by Phlogiston - 04-06-2018, 09:12 PM
RE: Chassis Restoration - by klondike98 - 04-06-2018, 10:07 PM
RE: Chassis Restoration - by Phlogiston - 04-07-2018, 09:57 AM
RE: Chassis Restoration - by Phlogiston - 04-08-2018, 02:34 PM
RE: Chassis Restoration - by oscartg - 04-14-2018, 10:17 AM
RE: Chassis Restoration - by Jeepeto - 04-15-2018, 08:38 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4916 online users. [Complete List]
» 1 Member(s) | 4915 Guest(s)
