70 cathedral speaker baffle/plate?
I don't suppose anyone out there has an accurate tracing of the sort of heart-shaped baffle or plate that the 70 loudspeaker mounts on? I have a good playing set but the repairman or whoever reworked it, did not install that part in the cabinet under the speaker. I would like to make a repro for eventual installation. I would assume an original or repro would be quite expensive. Thanks, Tom
70 cathedral speaker baffle/plate? - by tom2 - 07-03-2010, 11:55 AM
Re: 70 cathedral speaker baffle/plate? - by tom2 - 07-08-2010, 06:59 PM
Re: 70 cathedral speaker baffle/plate? - by tom2 - 07-08-2010, 07:04 PM
There are currently 9580 online users. [Complete List]
» 2 Member(s) | 9578 Guest(s)
