Philco 112B shadow mask?
The console model 112 with a slanted speaker board would have to be the 112X:
http://philcoradio.com/gallery2/1932a/#M...2X_Console
OK - so here are some detailed pictures of the mask and mount on mine:
https://flic.kr/s/aHsmhmi9au
Because the mask is curved I wrapped a piece of paper around it and made a pencil rubbing. I then took measurements with digital calipers:
I hope this helps and good luck!
Philco 112B shadow mask? - by dirkbuddy - 04-06-2018, 08:51 PM
RE: Philco 112B shadow mask? - by dirkbuddy - 04-06-2018, 09:16 PM
RE: Philco 112B shadow mask? - by dirkbuddy - 04-06-2018, 09:25 PM
RE: Philco 112B shadow mask? - by Nathan Slingerland - 04-09-2018, 12:23 AM
RE: Philco 112B shadow mask? - by dirkbuddy - 04-13-2018, 07:18 AM
Eico 232 VTVM Schematic
There are currently 9851 online users. [Complete List]
» 1 Member(s) | 9850 Guest(s)
