#61
Ok! I have tried with 90vac and rectifier on place, switch on and nothing made smoke Icon_smile checking the tubes all filaments are normal, 5Y4 is hot but less than first try and now I can see a small glow in what I think are the filaments in both sides of the black "shields" inside the glass(first try nothing), checked the voltage in #56 and is arround 250vdc, the schematics say something arround 330vdc I will try later to go full voltage and I will tell here the results. Thanks again for the help to get back to life this radio!
Philco 37-610 tombstone restoration - by Jeepeto - 02-09-2018, 08:58 AM
RE: Philco 37-610 tombstone restoration - by Jeepeto - 04-09-2018, 09:55 AM
Users browsing this thread: 24 Guest(s)
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4917 online users. [Complete List]
» 1 Member(s) | 4916 Guest(s)
