Philcophone Intercom Set
I looked around and couldn't find much on a Philcophone w/that tube set. The US models had a series strung heater rather than a power transformer like your set. Over here the model numbers for them start in the low 900's like 901- 908 or so.
Philcophone Intercom Set - by Antipodal - 04-09-2018, 05:53 AM
RE: Philcophone Intercom Set - by Radioroslyn - 04-09-2018, 10:03 AM
RE: Philcophone Intercom Set - by Antipodal - 04-09-2018, 05:46 PM
RE: Philcophone Intercom Set - by Ron Ramirez - 04-09-2018, 06:40 PM
RE: Philcophone Intercom Set - by Antipodal - 04-09-2018, 08:07 PM
RE: Philcophone Intercom Set - by Ron Ramirez - 04-09-2018, 08:44 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4872 online users. [Complete List]
» 1 Member(s) | 4871 Guest(s)
