Philcophone Intercom Set
Thanks for your help and assistance on this one.
 You are probably right - this could be a New Zealand made set."Transformerless "sets were never popular here .Most sets made in N.Z. have used power transformers ( possibly because our mains voltage here is 240 volts) except in later years when many Philips sets were sold which were AC/DC.
Furthermore there is no sign of any model serial number on the chassis.
But do the U.S. made ones seem to use a third lead on the output transformer?
 Cheers and best wishes,
 David Fahy
Philcophone Intercom Set - by Antipodal - 04-09-2018, 05:53 AM
RE: Philcophone Intercom Set - by Radioroslyn - 04-09-2018, 10:03 AM
RE: Philcophone Intercom Set - by Antipodal - 04-09-2018, 05:46 PM
RE: Philcophone Intercom Set - by Ron Ramirez - 04-09-2018, 06:40 PM
RE: Philcophone Intercom Set - by Antipodal - 04-09-2018, 08:07 PM
RE: Philcophone Intercom Set - by Ron Ramirez - 04-09-2018, 08:44 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4831 online users. [Complete List]
» 1 Member(s) | 4830 Guest(s)
