Since no one has commented. Cute cathedral looking at some photos on the Net. Appears to have a photo paper finish. The schematic shows it to be a very basic 5 tube radio and should be fine for general listening. Does it have the RF sub chassis that sits on top on the main chassis? If so recommend removing it to get unencumbered access to the caps.
Richard
37-93 - by denver - 05-31-2010, 07:46 PM
Re: 37-93 - by rghines1 - 06-01-2010, 08:38 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
