Westinghouse WR10A
The AK55 that I did had a similar arrangement. I believe I used a piece of rubber fuel line and glued it onto the shaft.  it works great.  See if you can find a size that works.
Westinghouse WR10A - by vecher - 02-17-2018, 12:36 AM
RE: Westinghouse WR10A - by Phlogiston - 02-17-2018, 12:00 PM
RE: Westinghouse WR10A - by vecher - 02-17-2018, 11:16 PM
RE: Westinghouse WR10A - by vecher - 02-27-2018, 08:26 PM
RE: Westinghouse WR10A - by Radioroslyn - 02-27-2018, 09:58 PM
RE: Westinghouse WR10A - by vecher - 02-28-2018, 02:26 AM
RE: Westinghouse WR10A - by David - 02-28-2018, 09:18 AM
RE: Westinghouse WR10A - by Eliot Ness - 02-28-2018, 09:36 AM
RE: Westinghouse WR10A - by EdHolland - 02-28-2018, 05:42 PM
RE: Westinghouse WR10A - by vecher - 03-31-2018, 12:03 AM
RE: Westinghouse WR10A - by Arran - 03-31-2018, 12:30 AM
RE: Westinghouse WR10A - by vecher - 04-01-2018, 12:21 AM
RE: Westinghouse WR10A - by Phlogiston - 04-01-2018, 10:51 AM
RE: Westinghouse WR10A - by vecher - 04-11-2018, 11:02 PM
RE: Westinghouse WR10A - by rfeenstra - 04-11-2018, 11:54 PM
RE: Westinghouse WR10A - by Eliot Ness - 04-12-2018, 05:38 AM
RE: Westinghouse WR10A - by vecher - 04-14-2018, 06:55 PM
RE: Westinghouse WR10A - by Radioroslyn - 04-14-2018, 08:22 PM
RE: Westinghouse WR10A - by vecher - 04-14-2018, 10:45 PM
RE: Westinghouse WR10A - by vecher - 04-14-2018, 11:23 PM
RE: Westinghouse WR10A - by vecher - 04-16-2018, 12:38 AM
There are currently 4564 online users. [Complete List]
» 2 Member(s) | 4562 Guest(s)
