Cheap xformer for tube output
I have never seen this one before. Here's a video on using a 70 volt line xformer as an tube output xformer. This guy shows how to calculate the impedance on the different winding's. He says they can be used for both single ended or push pull.
oops I forget to put in the link.
https://www.youtube.com/watch?v=-xrXjw7nt-g
Cheap xformer for tube output - by OZ4 - 04-12-2018, 02:07 PM
RE: Cheap xformer for tube output - by whirligig - 04-27-2018, 01:27 PM
RE: Cheap xformer for tube output - by morzh - 04-27-2018, 07:22 PM
RE: Cheap xformer for tube output - by Arran - 04-28-2018, 03:48 AM
RE: Cheap xformer for tube output - by Phlogiston - 04-28-2018, 11:40 AM
RE: Cheap xformer for tube output - by codefox1 - 05-29-2018, 01:39 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6931 online users. [Complete List]
» 1 Member(s) | 6930 Guest(s)
