Philco 40-81 Portable
Here is some good info on battery setshttp://www.antiqueradio.org/bsupply.htm
Kent.
Philco 40-81 Portable - by Pol-Cat - 06-01-2010, 08:35 PM
Re: Philco 40-81 Portable - by denver - 06-02-2010, 08:46 PM
Re: Philco 40-81 Portable - by exray - 06-02-2010, 09:36 PM
Re: Philco 40-81 Portable - by Ron Ramirez - 06-02-2010, 09:41 PM
Re: Philco 40-81 Portable - by Pol-Cat - 06-04-2010, 01:01 PM
There are currently 10609 online users. [Complete List]
» 2 Member(s) | 10607 Guest(s)
