Philco 49-901 restoration
Probably right after the AC switch. I'll add a fuse there too. It doesn't really matter though as long as it's somewhere in the series filament string
It's there to reduce surge current on startup and pretty much stays a constant temperature while the radio is on. You couldn't use it control a fan. I'll use an Ametherm SL12-22101 or equivalent. It's about 220 ohms at room temperature and drops to around 8 ohms with half an amp running through it.
Philco 49-901 restoration - by Bob Andersen - 02-27-2018, 12:01 AM
RE: Philco 49-901 restoration - by Bob Andersen - 02-27-2018, 12:53 AM
RE: Philco 49-901 restoration - by Ron Ramirez - 02-27-2018, 06:54 AM
RE: Philco 49-901 restoration - by Bob Andersen - 02-27-2018, 11:00 AM
RE: Philco 49-901 restoration - by Bob Andersen - 03-13-2018, 03:03 PM
RE: Philco 49-901 restoration - by Bob Andersen - 03-16-2018, 06:06 PM
RE: Philco 49-901 restoration - by Arran - 03-17-2018, 04:27 AM
RE: Philco 49-901 restoration - by Bob Andersen - 04-06-2018, 05:42 PM
RE: Philco 49-901 restoration - by Bob Andersen - 04-13-2018, 10:14 AM
The speaker table error?
Philco 70 antenna lead
There are currently 7089 online users. [Complete List]
» 1 Member(s) | 7088 Guest(s)
