201X chassis
The filters have the same setup as my 200X. They mount like a model 60 w/a metal band secured in the center and on each end to hold the caps in place. From what I see the tubes are in the correct places.
201X chassis - by Patrick - 04-15-2018, 01:35 PM
RE: 201X chassis - by Nathan Slingerland - 04-15-2018, 02:48 PM
RE: 201X chassis - by Radioroslyn - 04-15-2018, 03:47 PM
RE: 201X chassis - by Patrick - 04-15-2018, 04:35 PM
There are currently 3107 online users. [Complete List]
» 1 Member(s) | 3106 Guest(s)
