Kirk's 37-610
Any time you put a cap across live mains power, you should use at least X-rated cap, and every time the cap crosses between the Mains and the chassis (or any touchable by user metal part) - Y-cap.
Otherwise these caps are not necessary.
Kirk's 37-610 - by morzh - 03-31-2018, 10:43 PM
RE: Kirk's 37-610 - by morzh - 04-01-2018, 01:24 PM
RE: Kirk's 37-610 - by morzh - 04-16-2018, 11:15 AM
RE: Kirk's 37-610 - by WyTex - 04-16-2018, 11:55 AM
RE: Kirk's 37-610 - by morzh - 04-16-2018, 12:13 PM
RE: Kirk's 37-610 - by WyTex - 04-16-2018, 01:28 PM
RE: Kirk's 37-610 - by morzh - 05-04-2018, 08:36 PM
RE: Kirk's 37-610 - by morzh - 05-05-2018, 07:34 PM
RE: Kirk's 37-610 - by Jeepeto - 05-07-2018, 05:26 PM
RE: Kirk's 37-610 - by morzh - 05-07-2018, 06:10 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4870 online users. [Complete List]
» 2 Member(s) | 4868 Guest(s)
