Philco 40-81 Portable
Ron Ramirez Wrote:Also, I suggest you contact Batterymaker - he makes reproduction batteries which look just like the originals, but use modern batteries inside.
batterymaker AT gmail DOT com
He's also a Phorum member and posts here from time to time. I think I would rather have the reproduction battery from Batterymaker than try converting this set to AC - if you do, you're losing its intended purpose which was to be a portable radio.
Good advice! I'm on it!! Thanks and regards, Frank
Philco 40-81 Portable - by Pol-Cat - 06-01-2010, 08:35 PM
Re: Philco 40-81 Portable - by denver - 06-02-2010, 08:46 PM
Re: Philco 40-81 Portable - by exray - 06-02-2010, 09:36 PM
Re: Philco 40-81 Portable - by Ron Ramirez - 06-02-2010, 09:41 PM
Re: Philco 40-81 Portable - by Pol-Cat - 06-04-2010, 01:01 PM
