If you have your pics in Windows, just use the viewer and rotate - it is automatically saved in the rotated way you choose.
Then post it here.
38-116 - by wardmc1 - 04-16-2018, 09:00 PM
RE: 38-116 - by Brad Winder - 04-17-2018, 10:53 AM
RE: 38-116 - by morzh - 04-17-2018, 11:52 AM
RE: 38-116 - by wardmc1 - 04-17-2018, 01:25 PM
RE: 38-116 - by wardmc1 - 04-17-2018, 07:10 PM
RE: 38-116 - by Radioroslyn - 04-17-2018, 10:22 PM
RE: 38-116 - by Brad Winder - 04-17-2018, 11:02 PM
RE: 38-116 - by tbone - 05-19-2018, 08:35 AM
There are currently 10387 online users. [Complete List]
» 1 Member(s) | 10386 Guest(s)
