noise on radio during the day **SOLVED**
I have to admit, it's getting worse around here all the time. With everything using wall warts and nothing actually being able to be shut off nowadays, just going into sleep mode, there is noise all the time. People using their Chinese junk in their particle board palaces!
RE: noise on radio during the day - by Phlogiston - 04-18-2018, 11:34 AM
RE: noise on radio during the day - by morzh - 04-18-2018, 11:59 AM
RE: noise on radio during the day - by WyTex - 04-18-2018, 12:00 PM
RE: noise on radio during the day - by morzh - 04-18-2018, 12:03 PM
RE: noise on radio during the day - by Phlogiston - 04-18-2018, 01:52 PM
RE: noise on radio during the day - by David - 04-18-2018, 02:34 PM
RE: noise on radio during the day - by WyTex - 04-18-2018, 02:56 PM
RE: noise on radio during the day - by morzh - 04-18-2018, 03:59 PM
RE: noise on radio during the day - by falcon123 - 04-18-2018, 10:59 PM
RE: noise on radio during the day - by Jayce - 04-18-2018, 11:12 PM
RE: noise on radio during the day - by rfeenstra - 04-19-2018, 12:04 AM
RE: noise on radio during the day - by jcassity - 04-19-2018, 09:02 AM
RE: noise on radio during the day - by rfeenstra - 04-19-2018, 09:28 AM
RE: noise on radio during the day - by jcassity - 04-19-2018, 10:52 AM
RE: noise on radio during the day - by jcassity - 04-19-2018, 10:53 AM
RE: noise on radio during the day - by Phlogiston - 04-19-2018, 11:30 AM
RE: noise on radio during the day - by Kestas - 04-19-2018, 12:09 PM
RE: noise on radio during the day - by 35Z5 - 04-19-2018, 12:51 PM
RE: noise on radio during the day - by David - 04-19-2018, 01:54 PM
RE: noise on radio during the day - by Chris h - 04-19-2018, 10:57 PM
RE: noise on radio during the day - by 462ron - 04-20-2018, 08:02 AM
RE: noise on radio during the day - by jcassity - 04-20-2018, 11:46 AM
RE: noise on radio during the day - by EdHolland - 04-20-2018, 02:18 PM
RE: noise on radio during the day - by jcassity - 04-20-2018, 09:24 PM
RE: noise on radio during the day - by jcassity - 04-20-2018, 09:34 PM
RE: noise on radio during the day - by 35Z5 - 04-21-2018, 09:38 AM
RE: noise on radio during the day - by vinzer - 04-21-2018, 10:33 AM
RE: noise on radio during the day - by vinzer - 04-21-2018, 10:35 AM
RE: noise on radio during the day - by jcassity - 04-23-2018, 10:05 AM
RE: noise on radio during the day - by jcassity - 04-23-2018, 10:11 AM
RE: noise on radio during the day - by jcassity - 04-23-2018, 05:07 PM
RE: noise on radio during the day - by EdHolland - 04-24-2018, 12:02 AM
RE: noise on radio during the day - by jcassity - 04-24-2018, 07:43 AM
RE: noise on radio during the day - by Phlogiston - 04-24-2018, 10:03 AM
RE: noise on radio during the day - by jcassity - 04-24-2018, 01:11 PM
RE: noise on radio during the day - by jcassity - 04-25-2018, 09:36 PM
RE: noise on radio during the day - by Phlogiston - 04-25-2018, 10:34 PM
RE: noise on radio during the day - by jcassity - 04-26-2018, 01:28 PM
RE: noise on radio during the day - by 462ron - 04-26-2018, 03:08 PM
RE: noise on radio during the day - by morzh - 04-26-2018, 03:12 PM
RE: noise on radio during the day - by jcassity - 04-26-2018, 09:05 PM
RE: noise on radio during the day - by cpollock - 04-26-2018, 10:10 PM
RE: noise on radio during the day - by tbone - 05-05-2018, 09:11 AM
RE: noise on radio during the day - by Ed Locker - 05-05-2018, 09:29 AM
RE: noise on radio during the day - by Ed Locker - 05-05-2018, 09:43 AM
RE: noise on radio during the day - by cpollock - 05-05-2018, 09:39 PM
RE: noise on radio during the day - by Ed Locker - 05-07-2018, 09:09 AM
RE: noise on radio during the day - by tbone - 05-10-2018, 07:29 PM
RE: noise on radio during the day - by Ed Locker - 05-10-2018, 08:02 PM
RE: noise on radio during the day - by codefox1 - 05-11-2018, 08:42 AM
RE: noise on radio during the day - by Phlogiston - 05-11-2018, 09:39 AM
RE: noise on radio during the day - by jcassity - 05-12-2018, 10:37 PM
Users browsing this thread: 14 Guest(s)
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3875 online users. [Complete List]
» 1 Member(s) | 3874 Guest(s)
