Scott 16 - Restoration Begun
Nickel can be plated directly onto steel. Actually acid-copper can not be plated directly onto steel, but there is another process for that. If I want to copper plat a chassis I have to nickel plat it first otherwise the acid in the copper bath dissolves the steel - and ruins the copper bath.
The nickel is polished very smooth and then chrome is applied. It is like a clear coat on a painted surface, but has lots of imperfections so it will not protect by itself.
Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 12:48 AM
RE: Scott 16 - Restoration Begun - by Brad Winder - 12-28-2017, 02:16 AM
RE: Scott 16 - Restoration Begun - by Eliot Ness - 12-28-2017, 11:03 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 12:24 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 03:37 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 06:50 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 10:01 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 10:42 PM
RE: Scott 16 - Restoration Begun - by tasar - 02-27-2018, 09:59 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 02-27-2018, 10:51 AM
RE: Scott 16 - Restoration Begun - by KCMike - 02-27-2018, 11:22 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 02-27-2018, 11:34 AM
RE: Scott 16 - Restoration Begun - by Arran - 03-02-2018, 02:24 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 03-24-2018, 10:52 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-18-2018, 08:39 PM
RE: Scott 16 - Restoration Begun - by morzh - 04-18-2018, 09:54 PM
RE: Scott 16 - Restoration Begun - by Arran - 04-19-2018, 11:48 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-20-2018, 12:10 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-20-2018, 09:55 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-20-2018, 10:21 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-20-2018, 11:03 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 01:15 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-22-2018, 10:36 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 12:30 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-22-2018, 12:39 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 09:25 PM
RE: Scott 16 - Restoration Begun - by Arran - 04-23-2018, 02:45 AM
RE: Scott 16 - Restoration Begun - by Arran - 04-23-2018, 02:54 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 08:28 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-23-2018, 09:12 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 10:16 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-23-2018, 12:04 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 01:02 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-26-2018, 08:39 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-26-2018, 10:30 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-27-2018, 10:03 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-27-2018, 10:20 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 10:30 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 11:32 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 06-22-2018, 02:47 PM
RE: Scott 16 - Restoration Begun - by Brad Winder - 06-22-2018, 04:56 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 05:57 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-23-2018, 12:22 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 06-23-2018, 01:37 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 07-03-2018, 04:45 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-28-2018, 08:10 PM
RE: Scott 16 - Restoration Begun - by KCMike - 09-28-2018, 09:10 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-28-2018, 09:16 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-29-2018, 11:12 PM
RE: Scott 16 - Restoration Begun - by KCMike - 09-30-2018, 07:11 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 10-03-2018, 11:04 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 10-12-2018, 09:17 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-30-2019, 06:53 PM
RE: Scott 16 - Restoration Begun - by Scott D - 04-25-2020, 07:27 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-26-2020, 12:16 AM
There are currently 9726 online users. [Complete List]
» 2 Member(s) | 9724 Guest(s)
