noise on radio during the day **SOLVED**
Threads: 46
City: Gap Mills Wv 24941
(04-20-2018, 02:18 PM)EdHolland Wrote: Interesting (but annoying) problem. When the noise changes during the day, how rapid is the change? Does it fade out over 1/2 hour, change pitch or tone, or drop out suddenly?
That might provide another clue.
Ed
i think i know where you are going, thought about that also
update,,, the noise slowly faded out at around 8pm, then around 8:30 hardly any noise then just now leaving the garage (doing an 87 cougar resto), the noise was barely noticeable.
never had this issue during the winter,,, i think i noticed it last summer but was very new to tube radio tech and resto then. this is only my second summer running tube radios. my 46-1226 & my AA5 S38-d hallicrafters both do the same thing.
I can easily move the antenna, thinking of not using the pole on my chimney, just omitt that and continue the wire up into the tall maple with a weight, its another 30ft higher.
the reasons i think its sun related is that my upper story dormer roof line is darn 'near' optiimal for my location at 17deg for solar panels.
(This post was last modified: 04-20-2018, 09:29 PM by jcassity.)
RE: noise on radio during the day - by jcassity - 04-20-2018, 09:24 PM
Users browsing this thread: 17 Guest(s)
91H Code 126 Restore
Thanks Arran,
I'm convinced the power cord is good but have a nice repro plug for it. Would it be prudent to add a fus...RealRider — 07:28 PM |
As I was studying this schematic I was wondering what does this dotted line means? I haven't traced it out yet.
An o...RealRider — 07:22 PM |
When it comes to the cloth covered power cords, if they are not frayed, and are flexible, and if I can bend one without ...Arran — 06:21 PM |
Could be. The central cylinder is OK, but the sides are...well. What's done is done.
I wonder if some standard bobbine w...morzh — 06:02 PM |
Mike;
As I was saying it doesn't look like they used much of a bobbin for the field coil, not like a Magnavox one wou...Arran — 05:49 PM |
This AK84 was bought, I think, last fall.
For a whopping $100.
It has been, according to the seller, restored.
As I go ...morzh — 05:48 PM |
Plus I forgot that I have a spare complete Philco FC speaker, that would work perfectly, now that I don’t need it. Got i...Radios1340 — 05:36 PM |
Duh! I guess I can’t read an ohm meter today. I took the oscillator coil out and will take some readings tomorrow.Radios1340 — 05:30 PM |
Well, I killed the coil.
Tried to get to the end of that oxidated spot, but while holding the coil in hand, i let it sl...morzh — 05:27 PM |
It does not require taking apart.
Find an opening, any gap that would lead inside, where the resistive element and the ...morzh — 04:59 PM |
There are currently 4978 online users. [Complete List] » 1 Member(s) | 4977 Guest(s)
