Scott 16 - Restoration Begun
I cleaned mine with a damp rag.
People - I for one - have tried to rebuild the candohm resistors. Opening the outer case is a real problem. The other issue is getting nichrome wire with a high enough resistance for sections with resistance above a couple of hundred ohms. (Nichrome with resistance of an ohm or 2 per foot is available but this would require close to 100 ohms - or more, per foot)
In several radios (2 Zenith Strats) I have used a knife to score the wire, opening all of the windings, so that there is no possibility of an intermittent, and then hid a 20W wirewound under the old candohm for originality/looks. Also got some blowback on ARF from the non-restoration know-it -alls.
The original is insulated with fish-paper (possibly asbestos). If it is not visibly burned or cracked, it should provide adequate insulation for the one-wind on each end of the candohm that is still connected to the circuit.
Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 12:48 AM
RE: Scott 16 - Restoration Begun - by Brad Winder - 12-28-2017, 02:16 AM
RE: Scott 16 - Restoration Begun - by Eliot Ness - 12-28-2017, 11:03 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 12:24 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 03:37 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 06:50 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 10:01 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 10:42 PM
RE: Scott 16 - Restoration Begun - by tasar - 02-27-2018, 09:59 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 02-27-2018, 10:51 AM
RE: Scott 16 - Restoration Begun - by KCMike - 02-27-2018, 11:22 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 02-27-2018, 11:34 AM
RE: Scott 16 - Restoration Begun - by Arran - 03-02-2018, 02:24 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 03-24-2018, 10:52 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-18-2018, 08:39 PM
RE: Scott 16 - Restoration Begun - by morzh - 04-18-2018, 09:54 PM
RE: Scott 16 - Restoration Begun - by Arran - 04-19-2018, 11:48 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-20-2018, 12:10 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-20-2018, 09:55 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-20-2018, 10:21 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-20-2018, 11:03 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 01:15 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-22-2018, 10:36 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 12:30 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-22-2018, 12:39 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 09:25 PM
RE: Scott 16 - Restoration Begun - by Arran - 04-23-2018, 02:45 AM
RE: Scott 16 - Restoration Begun - by Arran - 04-23-2018, 02:54 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 08:28 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-23-2018, 09:12 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 10:16 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-23-2018, 12:04 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 01:02 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-26-2018, 08:39 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-26-2018, 10:30 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-27-2018, 10:03 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-27-2018, 10:20 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 10:30 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 11:32 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 06-22-2018, 02:47 PM
RE: Scott 16 - Restoration Begun - by Brad Winder - 06-22-2018, 04:56 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 05:57 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-23-2018, 12:22 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 06-23-2018, 01:37 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 07-03-2018, 04:45 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-28-2018, 08:10 PM
RE: Scott 16 - Restoration Begun - by KCMike - 09-28-2018, 09:10 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-28-2018, 09:16 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-29-2018, 11:12 PM
RE: Scott 16 - Restoration Begun - by KCMike - 09-30-2018, 07:11 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 10-03-2018, 11:04 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 10-12-2018, 09:17 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-30-2019, 06:53 PM
RE: Scott 16 - Restoration Begun - by Scott D - 04-25-2020, 07:27 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-26-2020, 12:16 AM
Philco 91 Tuning Condenser
There are currently 10020 online users. [Complete List]
» 1 Member(s) | 10019 Guest(s)
