Philco chassis 44 Newbbie help,
New to this site, 1st post.
I am restoring a philco standup radio chassis 44 looks like tuner is am and short wave.
There are 3 rubber tires in the tuner section, the one behind the dial plate and 2 more used in tuning and fine tuning. I got 2 of them but I need the 3rd(its the inner most one farthest from the dial plate) it is totally missing so I cant get it rebuilt.
Ayone have any thoughts or help. Thanks much appricated
Rich
Philco chassis 44 Newbbie help, - by safeshow - 04-22-2018, 10:53 AM
RE: Philco chassis 44 Newbbie help, - by safeshow - 04-22-2018, 05:44 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7723 online users. [Complete List]
» 2 Member(s) | 7721 Guest(s)
