Transporting a Philco 37-690
Russ
Mine disintegrated and fell making a big gaping hole in the cone. Probably way before I bought it.
It separated very neatly as if cut to make two cones, one on top and the cut base. It as easy putting it back together: drilled a hole through, put some glue, put a long wood screw to hold the two together: qith the glue I think it'll hold forever. But I wonder, the way it separated, if it was made from two glued cones in the first place: the separation surfaces were very clean.
Transporting a Philco 37-690 - by Kenradio - 04-22-2018, 05:38 AM
RE: Transporting a Philco 37-690 - by Ron Ramirez - 04-22-2018, 09:40 AM
RE: Transporting a Philco 37-690 - by Kenradio - 04-22-2018, 10:23 AM
RE: Transporting a Philco 37-690 - by Phlogiston - 04-22-2018, 10:42 AM
RE: Transporting a Philco 37-690 - by morzh - 04-22-2018, 11:12 AM
RE: Transporting a Philco 37-690 - by Phlogiston - 04-22-2018, 11:17 AM
RE: Transporting a Philco 37-690 - by morzh - 04-22-2018, 11:22 AM
RE: Transporting a Philco 37-690 - by Kenradio - 04-23-2018, 04:42 AM
RE: Transporting a Philco 37-690 - by Kenradio - 04-29-2018, 05:01 AM
RE: Transporting a Philco 37-690 - by morzh - 04-29-2018, 12:57 PM
RE: Transporting a Philco 37-690 - by Kenradio - 04-29-2018, 01:36 PM
RE: Transporting a Philco 37-690 - by morzh - 04-29-2018, 05:19 PM
RE: Transporting a Philco 37-690 - by Phlogiston - 04-29-2018, 10:06 PM
RE: Transporting a Philco 37-690 - by Phlogiston - 05-01-2018, 12:17 PM
RE: Transporting a Philco 37-690 - by Kenradio - 05-01-2018, 03:49 PM
RE: Transporting a Philco 37-690 - by morzh - 05-01-2018, 04:00 PM
RE: Transporting a Philco 37-690 - by Brad Winder - 05-02-2018, 08:36 PM
RE: Transporting a Philco 37-690 - by Kenradio - 05-03-2018, 05:58 AM
RE: Transporting a Philco 37-690 - by morzh - 05-03-2018, 07:52 AM
RE: Transporting a Philco 37-690 - by Brad Winder - 05-03-2018, 10:19 AM
RE: Transporting a Philco 37-690 - by morzh - 05-03-2018, 10:27 AM
RE: Transporting a Philco 37-690 - by Ron Ramirez - 05-03-2018, 11:58 AM
RE: Transporting a Philco 37-690 - by morzh - 05-03-2018, 01:15 PM
RE: Transporting a Philco 37-690 - by Ron Ramirez - 05-03-2018, 01:18 PM
RE: Transporting a Philco 37-690 - by morzh - 05-03-2018, 01:19 PM
RE: Transporting a Philco 37-690 - by Kenradio - 05-03-2018, 02:35 PM
RE: Transporting a Philco 37-690 - by Kenradio - 05-04-2018, 04:20 AM
RE: Transporting a Philco 37-690 - by tbone - 05-05-2018, 09:19 AM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
Hello Joseph, That looks great only thing I would make sure is that screw has good clean area where it contacts the gr...radiorich — 09:50 PM
