Little Mystery Radio
(04-22-2018, 01:39 PM)1MohrRadio Wrote:  I can't find a model 21 in the gallery.
http://philcoradio.com/gallery2/1931a/#B...dels_21_46
Only the shield is from a 21. That is not a Philco chassis.
Thread moved to Other Radios (Non-Philco).
Little Mystery Radio - by 1MohrRadio - 04-22-2018, 10:51 AM
RE: Little Mystery Radio - by morzh - 04-22-2018, 11:17 AM
RE: Little Mystery Radio - by 1MohrRadio - 04-22-2018, 01:39 PM
RE: Little Mystery Radio - by Ron Ramirez - 04-22-2018, 02:12 PM
RE: Little Mystery Radio - by 1MohrRadio - 04-22-2018, 05:40 PM
RE: Little Mystery Radio - by Radioroslyn - 04-22-2018, 06:36 PM
RE: Little Mystery Radio - by morzh - 04-22-2018, 11:05 PM
RE: Little Mystery Radio - by Arran - 04-23-2018, 02:27 AM
RE: Little Mystery Radio - by 1MohrRadio - 04-24-2018, 09:04 AM
RE: Little Mystery Radio - by palegreenthumb - 04-25-2018, 02:07 AM
RE: Little Mystery Radio - by Arran - 04-26-2018, 01:53 AM
