Scott 16 - Restoration Begun
This candohm does not allow one to get to the windings without actually taking the unit apart.  Some major metal bending would need to be accomplished.  Since it is the end section that connects to a ground lug right next to the end, I could just not hook up the end terminal and let it float, preventing any intermittent issues.  I'll look into the Dale resistors.  I can mount it so that it is not too obtrusive.  Thanks for your help!
Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 12:48 AM
RE: Scott 16 - Restoration Begun - by Brad Winder - 12-28-2017, 02:16 AM
RE: Scott 16 - Restoration Begun - by Eliot Ness - 12-28-2017, 11:03 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 12:24 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 03:37 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 06:50 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-28-2017, 10:01 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 12-28-2017, 10:42 PM
RE: Scott 16 - Restoration Begun - by tasar - 02-27-2018, 09:59 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 02-27-2018, 10:51 AM
RE: Scott 16 - Restoration Begun - by KCMike - 02-27-2018, 11:22 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 02-27-2018, 11:34 AM
RE: Scott 16 - Restoration Begun - by Arran - 03-02-2018, 02:24 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 03-24-2018, 10:52 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-18-2018, 08:39 PM
RE: Scott 16 - Restoration Begun - by morzh - 04-18-2018, 09:54 PM
RE: Scott 16 - Restoration Begun - by Arran - 04-19-2018, 11:48 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-20-2018, 12:10 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-20-2018, 09:55 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-20-2018, 10:21 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-20-2018, 11:03 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 01:15 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-22-2018, 10:36 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 12:30 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-22-2018, 12:39 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-22-2018, 09:25 PM
RE: Scott 16 - Restoration Begun - by Arran - 04-23-2018, 02:45 AM
RE: Scott 16 - Restoration Begun - by Arran - 04-23-2018, 02:54 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 08:28 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-23-2018, 09:12 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 10:16 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-23-2018, 12:04 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-23-2018, 01:02 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-26-2018, 08:39 PM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-26-2018, 10:30 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-27-2018, 10:03 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 04-27-2018, 10:20 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 10:30 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 11:32 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 06-22-2018, 02:47 PM
RE: Scott 16 - Restoration Begun - by Brad Winder - 06-22-2018, 04:56 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-22-2018, 05:57 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 06-23-2018, 12:22 AM
RE: Scott 16 - Restoration Begun - by Phlogiston - 06-23-2018, 01:37 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 07-03-2018, 04:45 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-28-2018, 08:10 PM
RE: Scott 16 - Restoration Begun - by KCMike - 09-28-2018, 09:10 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-28-2018, 09:16 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 09-29-2018, 11:12 PM
RE: Scott 16 - Restoration Begun - by KCMike - 09-30-2018, 07:11 AM
RE: Scott 16 - Restoration Begun - by rfeenstra - 10-03-2018, 11:04 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 10-12-2018, 09:17 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 12-30-2019, 06:53 PM
RE: Scott 16 - Restoration Begun - by Scott D - 04-25-2020, 07:27 PM
RE: Scott 16 - Restoration Begun - by rfeenstra - 04-26-2020, 12:16 AM
Philco 91 Tuning Condenser
