noise on radio during the day **SOLVED**
#37
i dont have enough "straight" or level surface land to do it the right way.
i have 1000' in length of land but no more than 200 or so feet at any given point is on the same plane.
RE: noise on radio during the day - by Phlogiston - 04-18-2018, 11:34 AM
RE: noise on radio during the day - by morzh - 04-18-2018, 11:59 AM
RE: noise on radio during the day - by WyTex - 04-18-2018, 12:00 PM
RE: noise on radio during the day - by morzh - 04-18-2018, 12:03 PM
RE: noise on radio during the day - by Phlogiston - 04-18-2018, 01:52 PM
RE: noise on radio during the day - by David - 04-18-2018, 02:34 PM
RE: noise on radio during the day - by WyTex - 04-18-2018, 02:56 PM
RE: noise on radio during the day - by morzh - 04-18-2018, 03:59 PM
RE: noise on radio during the day - by falcon123 - 04-18-2018, 10:59 PM
RE: noise on radio during the day - by Jayce - 04-18-2018, 11:12 PM
RE: noise on radio during the day - by rfeenstra - 04-19-2018, 12:04 AM
RE: noise on radio during the day - by jcassity - 04-19-2018, 09:02 AM
RE: noise on radio during the day - by rfeenstra - 04-19-2018, 09:28 AM
RE: noise on radio during the day - by jcassity - 04-19-2018, 10:52 AM
RE: noise on radio during the day - by jcassity - 04-19-2018, 10:53 AM
RE: noise on radio during the day - by Phlogiston - 04-19-2018, 11:30 AM
RE: noise on radio during the day - by Kestas - 04-19-2018, 12:09 PM
RE: noise on radio during the day - by 35Z5 - 04-19-2018, 12:51 PM
RE: noise on radio during the day - by David - 04-19-2018, 01:54 PM
RE: noise on radio during the day - by Chris h - 04-19-2018, 10:57 PM
RE: noise on radio during the day - by 462ron - 04-20-2018, 08:02 AM
RE: noise on radio during the day - by jcassity - 04-20-2018, 11:46 AM
RE: noise on radio during the day - by EdHolland - 04-20-2018, 02:18 PM
RE: noise on radio during the day - by jcassity - 04-20-2018, 09:24 PM
RE: noise on radio during the day - by jcassity - 04-20-2018, 09:34 PM
RE: noise on radio during the day - by 35Z5 - 04-21-2018, 09:38 AM
RE: noise on radio during the day - by vinzer - 04-21-2018, 10:33 AM
RE: noise on radio during the day - by vinzer - 04-21-2018, 10:35 AM
RE: noise on radio during the day - by jcassity - 04-23-2018, 10:05 AM
RE: noise on radio during the day - by jcassity - 04-23-2018, 10:11 AM
RE: noise on radio during the day - by jcassity - 04-23-2018, 05:07 PM
RE: noise on radio during the day - by EdHolland - 04-24-2018, 12:02 AM
RE: noise on radio during the day - by jcassity - 04-24-2018, 07:43 AM
RE: noise on radio during the day - by Phlogiston - 04-24-2018, 10:03 AM
RE: noise on radio during the day - by jcassity - 04-24-2018, 01:11 PM
RE: noise on radio during the day - by jcassity - 04-25-2018, 09:36 PM
RE: noise on radio during the day - by Phlogiston - 04-25-2018, 10:34 PM
RE: noise on radio during the day - by jcassity - 04-26-2018, 01:28 PM
RE: noise on radio during the day - by 462ron - 04-26-2018, 03:08 PM
RE: noise on radio during the day - by morzh - 04-26-2018, 03:12 PM
RE: noise on radio during the day - by jcassity - 04-26-2018, 09:05 PM
RE: noise on radio during the day - by cpollock - 04-26-2018, 10:10 PM
RE: noise on radio during the day - by tbone - 05-05-2018, 09:11 AM
RE: noise on radio during the day - by Ed Locker - 05-05-2018, 09:29 AM
RE: noise on radio during the day - by Ed Locker - 05-05-2018, 09:43 AM
RE: noise on radio during the day - by cpollock - 05-05-2018, 09:39 PM
RE: noise on radio during the day - by Ed Locker - 05-07-2018, 09:09 AM
RE: noise on radio during the day - by tbone - 05-10-2018, 07:29 PM
RE: noise on radio during the day - by Ed Locker - 05-10-2018, 08:02 PM
RE: noise on radio during the day - by codefox1 - 05-11-2018, 08:42 AM
RE: noise on radio during the day - by Phlogiston - 05-11-2018, 09:39 AM
RE: noise on radio during the day - by jcassity - 05-12-2018, 10:37 PM
Users browsing this thread: 25 Guest(s)
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4892 online users. [Complete List]
» 2 Member(s) | 4890 Guest(s)
