Philco 60 Oscillator with a Weird Problem
Wow, it's been nearly a year since I posted this and I didn't give a conclusion. I apologize. Thanks to morhz and Steve I revisited this coil late last year and removed the secondary and corroded primary and rewound them. I installed this coil in another 60 that I cannabalized earlier and it now works. The second time around went much quicker. Thanks.
RE: Philco 60 Oscillator with a Weird Problem - by whirligig - 04-24-2018, 01:31 PM
The speaker table error?
Philco 70 antenna lead
There are currently 2192 online users. [Complete List]
» 1 Member(s) | 2191 Guest(s)
