How many loops
Tnx Guys
I thought that the copper loop wouldn't have enough inductance for the bc band
but having it connected to another coil makes sense. I only saw the one loop on
the diagram but just want to be sure.
How many loops - by 7estatdef - 06-07-2010, 09:10 PM
Re: How many loops - by Ron Ramirez - 06-07-2010, 10:01 PM
Re: How many loops - by Raleigh - 06-08-2010, 10:13 AM
Re: How many loops - by exray - 06-08-2010, 06:27 PM
Re: How many loops - by 7estatdef - 06-08-2010, 08:51 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6575 online users. [Complete List]
» 1 Member(s) | 6574 Guest(s)
